Hello, It’s my first time using Linux. I’d follow the manual in installing and setup Savapage successfully. But currently stuck at printing a document.
When I login to user web app and upload a document for printing, no printer shows even though added printers on the operating system are CUPS-BRF-Printer and Savapage.org printer shows “Ready”.
Then I log in as admin >> Proxy Printers and I find only CUPS-BRF-Printer/Generic Text… only (marked good but with configuration needed) and no Savapage.org printer showing.
Which is the printer I’m supposed to use for web printing?
Why is Savapage.org printer not showing in admin >> Proxy Printers?
Why am I not finding any printers when I try to print uploaded documents in user web app?
@godup Welcome! You need to configure the Media Sources any proxy printer before it can be used. The CUPS printer that prints to SavaPage is skipped as proxy printer.
Yes I understand I have to configure the media source but what is displayed on the admin web app is not same as what the manual depicted in section 4.8.2.3.Media Sources.
Attached is what I get on my interface and I don’t see buttons to make changes to Media source settings.
Okay… I have seen this and I have read through but still find it difficult to crack. I intend to use an hp laserjet P2055 printer. Where can get its .ppd file? if i modify the template file in opt >> savapage >> server >> custom >> cups as a .ppde for my printer what directory am I supposed to store .ppd and .ppde files?
@godup If you install hplib on your system the PPD files for HP printers will be available in CUPS, and you can pick the right driver when you add your printer in CUPS. In your case, pick “HP LaserJet p2055” and the media-source is resolved in SavaPage. For your reference see the Open Printing database for HP-LaserJet_P2055d and HP-LaserJet_P2055dn.
Actually, this is basic knowledge of Linux. If you nevertheless have trouble finding your way, send an email to support@savapage.org , so I can help you offline and report conclusions in this post.
Hello SavaPage Community, I discover savapage a some months ago and I finally got to try it and install it. but I have issues this is my problem. I have a cups printer server with 4 printers in it with Savapage installed. I can print a test page from the cups server to the printers so I know my configuration works. My problem is I cant get the printer to show in savapage clients view. I can see the printers in the Admin view but it tells me in red letters “Configuration Needed” I have added the PDD file of the printer in Savapage and assigned to the printer and the error does not go away. I have configure media on the printer and the error still there. One thing I notice when I configured media it does not give me an option to name the media but allows me to put price in it and active the preferer media file types. Can you please tell me what I am doing wrong? Thanks
