I have followed the steps here:
https://www.savapage.org/docs/manual/app-tools-ssl-key.html#app-tools-ssl-key-install-keystore
JKS is generated and valid according to keytool.
Keystore explorer can validate it also:
however restart fails with
2022-03-03 20:43:38,129 INFO SpInfo:63 -
| SavaPage 1.4.0-rc (Build 20220127)
| Copyright (c) 2011-2022 by Datraverse B.V.
| GNU Affero General Public License (AGPL)
| OpenJDK 64-Bit Server VM (1.8.0_312)
| Apache Derby 10.14.2.0 - (1828579)
| Running as user [savapage]
+------------------------------------------------------------------------+ [main]
2022-03-03 20:43:38,760 INFO SpInfo:89 -
| Visiting Guest.
2022-03-03 20:43:39,378 INFO SpInfo:119 - database.connection.pool.max > hibernate.c3p0.max_size [200] [main]
2022-03-03 20:43:39,378 INFO SpInfo:119 - database.connection.pool.min > hibernate.c3p0.min_size [5] [main]
2022-03-03 20:43:39,378 INFO SpInfo:119 - database.connection.idle-timeout-secs > hibernate.c3p0.timeout [600] [main]
2022-03-03 20:43:39,379 INFO SpInfo:119 - database.connection.idle-timeout-test-secs > hibernate.c3p0.idle_test_period [120] [main]
2022-03-03 20:43:39,379 INFO SpInfo:119 - database.connection.statement-cache > hibernate.c3p0.max_statements [50] [main]
2022-03-03 20:43:39,844 INFO SpInfo:119 - PDF Standard Fonts: [14] substitutes retrieved. [main]
2022-03-03 20:43:39,853 INFO SpInfo:119 - SSL Mail protocols [TLSv1.2] [main]
2022-03-03 20:43:44,239 INFO SpInfo:119 - SOffice converter started with 2 workers. [main]
2022-03-03 20:43:44,478 INFO SpInfo:119 - Print Job Status monitor started. [main]
2022-03-03 20:43:44,894 INFO SpInfo:119 - Database [tbl_sequences] OK. [main]
2022-03-03 20:43:44,958 INFO SpInfo:119 - Jetty 9.4.43.v20210629 [main]
2022-03-03 20:43:44,958 INFO SpInfo:119 - Web Server started on port 8631 and 8632 (SSL) [main]
2022-03-03 20:43:44,958 INFO SpInfo:119 - Web Server acceptor threads [1] and [1] (SSL) [main]
2022-03-03 20:43:44,958 INFO SpInfo:119 - server.threadpool.queue.capacity [3000] [main]
2022-03-03 20:43:44,959 INFO SpInfo:119 - server.threadpool.maxthreads [200] [main]
2022-03-03 20:43:44,960 INFO SpInfo:119 - server.threadpool.minthreads [20] [main]
2022-03-03 20:43:44,960 INFO SpInfo:119 - server.threadpool.idle-timeout-msec [30000] [main]
2022-03-03 20:43:44,960 INFO SpInfo:119 - server.session.scavenge.interval-sec [600] [main]
2022-03-03 20:43:44,961 INFO SpInfo:119 - SSL Cert Issuer [R3] self-signed. [main]
2022-03-03 20:43:44,961 INFO SpInfo:119 - SSL Cert Subject [printshop.example.com] [main]
2022-03-03 20:43:44,962 INFO SpInfo:119 - SSL Cert Created [March 3, 2022 8:14:06 PM] [main]
2022-03-03 20:43:44,962 INFO SpInfo:119 - SSL Cert Expires [June 1, 2022 5:07:35 PM] [main]
2022-03-03 20:43:45,055 INFO SpInfo:119 - Loaded plugins [0] [main]
2022-03-03 20:43:45,065 INFO SpInfo:119 - IPP Print Server started. [main]
2022-03-03 20:43:45,077 INFO SpInfo:119 - IP Print Server started on port 9100. [Thread-35]
2022-03-03 20:43:45,358 ERROR WebServer:1004 - Get Key failed: Given final block not properly padded. Such issues can arise if a bad key is used during decryption. [main]
java.security.UnrecoverableKeyException: Get Key failed: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at sun.security.pkcs12.PKCS12KeyStore.engineGetKey(PKCS12KeyStore.java:455)
at sun.security.provider.KeyStoreDelegator.engineGetKey(KeyStoreDelegator.java:96)
at sun.security.provider.JavaKeyStore$DualFormatJKS.engineGetKey(JavaKeyStore.java:71)
at java.security.KeyStore.getKey(KeyStore.java:1023)
at sun.security.ssl.SunX509KeyManagerImpl.<init>(SunX509KeyManagerImpl.java:145)
at sun.security.ssl.KeyManagerFactoryImpl$SunX509.engineInit(KeyManagerFactoryImpl.java:70)
at javax.net.ssl.KeyManagerFactory.init(KeyManagerFactory.java:256)
at org.eclipse.jetty.util.ssl.SslContextFactory.getKeyManagers(SslContextFactory.java:1249)
at org.eclipse.jetty.util.ssl.SslContextFactory$Server.getKeyManagers(SslContextFactory.java:2363)
at org.eclipse.jetty.util.ssl.SslContextFactory.load(SslContextFactory.java:373)
at org.eclipse.jetty.util.ssl.SslContextFactory.doStart(SslContextFactory.java:244)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:73)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
at org.eclipse.jetty.server.SslConnectionFactory.doStart(SslConnectionFactory.java:97)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:321)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:81)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:234)
at org.eclipse.jetty.server.Server.doStart(Server.java:401)
at org.savapage.server.WebServer.main(WebServer.java:988)
Caused by: javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:975)
at com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:1056)
at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:853)
at com.sun.crypto.provider.PBES2Core.engineDoFinal(PBES2Core.java:323)
at javax.crypto.Cipher.doFinal(Cipher.java:2168)
at sun.security.pkcs12.PKCS12KeyStore.lambda$engineGetKey$0(PKCS12KeyStore.java:396)
at sun.security.pkcs12.PKCS12KeyStore$RetryWithZero.run(PKCS12KeyStore.java:285)
at sun.security.pkcs12.PKCS12KeyStore.engineGetKey(PKCS12KeyStore.java:390)
... 24 more
2022-03-03 20:43:46,070 INFO SpInfo:119 - | Cleaning AccountTrx [4] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,110 INFO SpInfo:119 - UserHomeClean
| User Home Clean | Conflicts | 0 |
| Scope | Before | Cleaned | After |
| Home | users | 1 | 0 | |
| Print-In | jobs | 1 | 0 | 1 |
| | size | 468 KB | 0 | 468 KB |
| Print-Hold | jobs | 0 | 0 | 0 |
| | size | 0 | 0 | 0 |
| Completed after 7 msec. |
+====================================================+ [DefaultQuartzScheduler_Worker-7]
2022-03-03 20:43:46,180 INFO SpInfo:119 - | 108ms : 0 AccountTrx cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,182 INFO SpInfo:119 - | Cleaning DocLog/AccountTrx [4] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,283 INFO SpInfo:119 - | 81ms : 0 DocLog/AccountTrx cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,285 INFO SpInfo:119 - | Cleaning DocLog/DocOut [4] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,369 INFO SpInfo:119 - | 82ms : 0 DocLog/DocOut cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,371 INFO SpInfo:119 - | Cleaning DocLog/DocIn [4] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,430 INFO SpInfo:119 - | 59ms : 0 DocLog/DocIn cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,439 INFO SpInfo:119 - | Cleaning User [1] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,453 INFO SpInfo:119 - | 14ms : 0 User cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,463 INFO SpInfo:119 - | Cleaning Printer [2] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,474 INFO SpInfo:119 - | 10ms : 0 Printer cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,480 INFO SpInfo:119 - | Cleaning IppQueue [7] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,489 INFO SpInfo:119 - | 8ms : 0 IppQueue cleaned. [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,498 INFO SpInfo:119 - | Cleaning Account [1] ... [DefaultQuartzScheduler_Worker-4]
2022-03-03 20:43:46,511 INFO SpInfo:119 - | 12ms : 0 Account cleaned. [DefaultQuartzScheduler_Worker-4]
I tried PCKS12 format for the keystore as well, but get a different error about invalid password so I reverted back to JKS format.
-Todd
